Altera_ForumHonored Contributor13 years agofloating number with synthetisable vhdl code Hi, I have to use floating number with my VHDL code wich wille be implemented in a de2 card so how can I use floating point?? I have seen that this method use number between (-128)et 127 if I...Show More
Altera_ForumHonored Contributor13 years agoThen you need to use the Altera floating point IP cores from the megawizard
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
