10 years agofloat data format are simulated in Modelsim
Hi, Now, I need to simulate output data of FPGA in Modelsim which data format is signal precision . the width of single precision is 32 ,and the modelsim view those 32 bits to integer. and now...
10 years agoif you use the floating point library in the IEEE library (which is part of the VHDL 2008 spec) then coverting to real is as simple as:
library ieee;
use ieee.std_logic_1164.all;
use ieee.float_lib.all;
signal a : std_logic_vector(31 downto 0);
signal r : real;
r <= bitstoreal(a);
