14 years agoFlattening Verilog Hierarchy for IP block creation
Guys, Wonder if someone could point me in the right direction. I would like to flatten my design hierarchy into 1 file so I can just encrypt that one file for making an IP block. With ove...
14 years agoThanks for your replies.
Rysc, Yes I am using Ampcrypt. You are correct that there is no need to combine the packages. However, as the design is over 60 files I would rather combine them for an easier IP delivery. The brick, So are you saying I could encrypt the design and then export a .qxp? I don't want to just encrypt my top level as there is nothing really in there. Great replies, Thanks for your continued support C
