16 years agoFixed Point Multiplication in Verilog or Quartus II
Hello, I plan to implement a controller digitally in my FPGA & it involves numerous fixed-point additions, multiplications & divisions. Therefore here is a generic question: Suppose ...
16 years agoThanks a lot fvm, for such an enlightening post.
@amilcar : Not that I couldn't understand how an overflow would occur in the case of multiplying two most negative numbers; what confused me was the term "two sign bits". But, now I completely understand what FvM had to say. Even I cross-checked my logic, and here's my elaborate proof: Consider this - All we need is to multiply 2 numbers A & B (which are 16-bit signed). We assume that (we have checked that) whatever range of values A & B will take (fractional or integer) - the integer-part of our "result_axb" is small enough to be represented by less than or equal to 15-bits. (i.e. -32768 <= result_axb <= 32767) Which means, that we have already checked that no overflow would occur with our result_AxB ( 'overflow' w.r.t. 16-bits signed representation ) now, in 32-bit signed representation: Any positive no. less than +32767: has all it 17 msb's [31:15] = 0 (= sign bit) Any negative no. greater than -32768: has all it 17 msb's [31:15] = 1 ( = sign bit) I am attempting to generate a 32-bit signed result: mult_out32 = k*l*m ( refer my 2nd post: A*B = K*L*(M/N) ). This product (K*L*M) may exceed the 16-bit signed range. But, since i'm sure that later on, dividing it by N (i.e. stripping-off its P LSBs) would bring the result back in the 16-bit signed range ... and in this resulting form, all its [31-p:15] msbs would be equal ) ... therefore, before stripping-off, these same bits are at the position [31:P+15], and hence these are necessarily equal ! (We can collectively call all these equal bits as 'The sign bit' !) So, summing up - I can rest assured that, iff I've checked the 16-bit overflow condition at the start - then mult_out32[31] & mult_out32[30:p+15] are all equal ! Moreover, result_axb = {mult_32out[31], mult_32out[p + 14 : p]};will give me the correct 16-bit signed result, in the end ! Hence proved ! :-) p.s.: Thanks again FvM, for helping me arrive at this proof; and also giving an Overflow-condition-checker, in case we wish to make a more generic module !
