ShengN_altera
2 months agoAMD Ryzen support Simultaneous Multithreading (SMT) if check this https://www.techpowerup.com/cpu-specs/ryzen-threadripper-pro-3995wx.c2314 Could you try to turn off through BIOS?
corestar
Contributor
2 months agoHello ShengN_altera ,
That worked!
I did not realize "SMT" was AMD's term for Hyper-threading. Still not clear why it caused a problem. It is supposedly transparent to user programs.
I went into the BIOS:
Advanced\AMD CBS\CPU Common Options\Thread Enablement
and changed SMD Control to disabled. It now completes the compile.
Hopefully it will not affect other programs, but at least I have a solution. Hyper-threading is probably a waste of time on a 64 core system anyway.
