AEsqu
Contributor
4 years agoFitter routing operation verbosity
Vivado brings several information while the routing is running (congestion level, TNS/WNS, ..)
which are quite useful.
Quartus stays totally quite and do not show any info,
only when ...
SyafieqS
4 years agoHi Alexandre,
May I know if there is any update from your end?
Regarding the info related to TNS,WNS, you can actually look at timing analyzer report in compilation report (assuming successfully pass the flow) with simplify information. You can see more details in Timing Analyzer for more other report.
AEsqu
Contributor
4 years agoOk so you confirm that verbosity cannot be changed during the run.
Let's close the ticket.
