AEsqu
Contributor
4 years agoFitter routing operation verbosity
Vivado brings several information while the routing is running (congestion level, TNS/WNS, ..)
which are quite useful.
Quartus stays totally quite and do not show any info,
only when ...
SyafieqS
4 years agoHi Alexandre,
You can find more information in compilation report regarding the routing. Judging from your snapshot, failed routing is due to resource used more that device capacity, you probably need to modify your code or do some optimization to reduce the resource.
