Fitter Pin Placement Constraint
I am a Lab Instructor at the University of Waterloo.
I have to provide some background context for the situation we now have.
An in-house board was developed way back when Quartus was still a part of Altera. Quartus was at v15.1. The pinout for the MAX10 FPGA was chosen and confirmed by the Fitter to be acceptable and the PCB was then designed and PCB Assemblies were made for numerous labs.
We have continued to use the Quartus v15.1 tools for the FPGA-related course using this board.
Starting with v16.1 and so on, the Fitter pin-placement rules have changed and the FPGA compiles no longer complete because one of the output pins (for driving an LED) is placed beside a PLL input pin.
The license for the v15.1 tools has finally expired and we are forced to move on to the newer tools.
Is there a setting somewhere with the Fitter, to ignore this placement constraint for our situation?
The Led pins are seldom changed and with the earlier v15.1 tools, there were no operational errors.
Thank you for your time,
kind regards,
Charles
Thank you !
Your work-around solution worked !!!!
All of the FPGA pins are assigned for the development board that we use in-house.
We use a .tcl script for the students to run before they begin their FPGA designs. The .tcl script has all pin assignment made.
When doing a Full Compile (v18.1 LITE) with the assignments the compile fails because of the earlier mentioned Fitter analysis.
If I then, comment out the pin assignment (see for leds[1] below) and save and run the .tcl file, the FPGA will now have that output pin unassigned.
Then, like you mentioned, the Fitter will auto-place that output pin to the only available pin left to the FPGA.
BUT this time, the compile will now complete without any error.
Thank you so much.
Charles
- sstrell
Oh, maybe you are saying that PIN_28 *is* the only pin available. Now it makes sense. I thought you meant that there was some other pin available that the Fitter was auto-assigning to.
As for your question about reserved pins, yes, that would work as a workaround for this as well (though of course this bug shouldn't be an issue in the first place). The fact that a direct assignment doesn't work and doing what you've done does work is silly.
