Fitter Pin Placement Constraint
- 3 years ago
Thank you !
Your work-around solution worked !!!!
All of the FPGA pins are assigned for the development board that we use in-house.
We use a .tcl script for the students to run before they begin their FPGA designs. The .tcl script has all pin assignment made.
When doing a Full Compile (v18.1 LITE) with the assignments the compile fails because of the earlier mentioned Fitter analysis.
If I then, comment out the pin assignment (see for leds[1] below) and save and run the .tcl file, the FPGA will now have that output pin unassigned.
Then, like you mentioned, the Fitter will auto-place that output pin to the only available pin left to the FPGA.
BUT this time, the compile will now complete without any error.
Thank you so much.
Charles
There's a patch to fix this in 16.1 at least:
https://www.intel.com/content/www/us/en/support/programmable/articles/000074027.html
This article says it was fixed in 17.0, so not sure why you're seeing it:
https://www.intel.com/content/www/us/en/support/programmable/articles/000087348.html
Have you tried any newer versions of Quartus?
- CKPope3 years ago
Thank you for that info.
You sent two links. The first one looks like it is more "in line" with the situation that I am raising.
The second seems to apply more to the case where pins can be reassigned for an FPGA project.
Thank you VERY MUCH for this info. I checked the READ_ME file contents for the first link and it mentions that a patch for v16.1 is required. I don't have the v16.1 tools on site but I have the v18.1 tools.
But I did try creating the quartus.ini file with the "disable....." instruction inside it, with the hope that it would work for the version of Quartus (v18.1)....... but NOPE .
The patch is definitely required for v16.1 tools.
But I can't find the v16.1 tools or any patch for later tool versions on the Intel FPGA s/w download site..
I don't know if you are able to provide any additional info to me or if I could could add something to a TCL file, but anything would be very appreciated.
Charles
