10 years agoFitter fails when placing ALTLVDS_RX instance on Arria V GX Starter Board
I am using the LVDS HSMC RX pins on the Arria V GX Starter Board, I have RX pins HSMA_RX_D[16:0] all to be clocked using HSMA_CLK_INP1 (all pins are LVDS). The incoming clock is 250MHz and the data i...
10 years ago --- Quote Start --- I'm not sure of the real reason for the problem but you do realize that the fitter is complaining about an output not an input don't you? What has the output clock got to do with the Rx DPA? --- Quote End --- I assume they are referring to the output of the pll. It is the input to the RX DPA
