11 years ago
Fitter Failed--Quartus II- Version 12.0-- Total Memory Bits usage 0%, LE usage 1232%
I am trying to synthesis a 2KB Ram( with 1024 locations and 16 bit data respectively), in VHDL using Quartus 2 version 12.0 in a 32 bit windows 7 operating system.
I am getting message as flow failed, and getting error as cannot fit design, and from the report, what I understand is the tool is trying to compile the design using LE's instead of block rams. Is there any way or option that I can change in the tool, and hence use total memory bits, instead of LEs?.
Here is the report that I am getting.
Flow Status Flow Failed - Mon Feb 16 16:51:05 2015
Quartus II 32-bit Version 12.0 Build 232 07/05/2012 SP 1 SJ Web Edition
Revision Name ping_pong_buffer
Top-level Entity Name ping_pong_buffer
Family Cyclone II
Device EP2C5F256I8
Timing Models Final
Total logic elements 56,779 / 4,608 ( 1232 % )
Total combinational functions 24,009 / 4,608 ( 521 % )
Dedicated logic registers 32,826 / 4,608 ( 712 % )
Total registers 32826
Total pins 33 / 158 ( 21 % )
Total virtual pins 0
Total memory bits 0 / 119,808 ( 0 % )
Embedded Multiplier 9-bit elements 0 / 26 ( 0 % )
Total PLLs 0 / 2 ( 0 % )
Manoj
    You need to copy one of the patterns that correctly infer ram.
    Things like resets or latching the read data on a different clock can cause LEs to be used instead of ram.
    Sounds like you didnt follow the template for ram inference, or you did something that a ram cannot do (like reset its contents).
    Why not post the code so we can have a look?
    --- Quote Start ---
    Sounds like you didnt follow the template for ram inference, or you did something that a ram cannot do (like reset its contents).Why not post the code so we can have a look?
    --- Quote End ---
    Hello Tricky and DSL,Thanks for your reply. Here is my code. I am trying to create a ping-pong buffer( two memories of size 2KB each. Which asserts an interrupt when one of the memories is full). I am attaching my code here with in a notepad file.
    The main problem comes because you didnt register the read address for the ram.
    --- Quote Start ---
    --- Quote End ---
    Hello Tricky,
    What do you mean by "didn't register the read address for the ram"?. I am sorry, but I am not able to understand that. Can you please elaborate a bit more on that?.
    Thanks for your time.
    Manoj
    you use the addr input without registering it first. To infer rams, they require you to have registered read address.
    As a beginner, you would probably be better off learning out to use a RAM by generating one from the megawizard.
    --- Quote Start ---
    you use the addr input without registering it first. To infer rams, they require you to have registered read address. As a beginner, you would probably be better off learning out to use a RAM by generating one from the megawizard.
    --- Quote End ---
    Thank you. It worked, after registering the read address.
    Kind Regards,
    Manoj
    I tried using the megawizard first, but it gave me a bunch of signals and statements which I couldn't comprehend. I will dig more into megawizard, and use it.
    Manoj
