anonimcs
Contributor
2 years agoFitter Error not able to detect any instance for core
Hi all, I have a project implemented on Quartus Prime 17.1 Standard version on Ubuntu 20.04 using an Arria10 and this project was working fine without any errors. Then I added 2 IP blocks (one custo...
- 1 year ago
Yes, the root cause was that there were multiple top level qsys files in the project (copy of each other, but the file names were different) for revisioning. I had to remove the unused qsys file from my qsf file. After that, I could compile the design all the way.
RichardT_altera
1 year agoHi,
May I know if the issue has been resolved and if you still need help with this case?
Richard Tan
anonimcs
Contributor
1 year agoYes, the root cause was that there were multiple top level qsys files in the project (copy of each other, but the file names were different) for revisioning. I had to remove the unused qsys file from my qsf file. After that, I could compile the design all the way.
