GD76's avatar
GD76
5 years ago
Fitter Error for fractional PLL
The error in fitting is as follows. Going thorugh the knowledge base, not clear what the solution is. It says "Location FRACTIONALPLL_X0_Y38_N0" already occupied. I can move to different location but not sure what constraint syntax is. Maybe others have seen the same issue.
Error (14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 fractional PLL(s)).
Error (175001): The Fitter cannot place 1 fractional PLL, which is within PLL Intel FPGA IP CPU3000Qsys_pll.
Info (175028): The fractional PLL name(s): CPU3000Qsys:u0|CPU3000Qsys_pll:pll|altera_pll:altera_pll_i|general[0].gpll~FRACTIONAL_PLL
Error (11238): The following 1 fractional PLL locations are already occupied, and the Fitter cannot merge the previously placed nodes with these instances. The nodes may have incompatible inputs or parameters.
Error (11239): Location FRACTIONALPLL_X0_Y38_N0 is already occupied by CPU3000Qsys:u0|CPU3000Qsys_ddr2:ddr2|CPU3000Qsys_ddr2_pll0:pll0|pll1~FRACTIONAL_PLL.
Error (12289): An error occurred while applying the periphery constraints. Review the offending constraints and rerun the Fitter.
  • What device family and Quartus version and edition (Standard, Pro) are you using?
    What IP are you using that might be conflicting with the use of a particular PLL?
    Have you made I/O pin assignments that might be conflicting?
  • sstrell's avatar
    sstrell
  • GD76's avatar
    GD76
    Device is Cyclone V (5CEFA4F23C7). Quartus Standard version 18.1. There are no IO pin conflict looking thorough the QSF file (attached) The IPs are many DDR2 has pll and NIOS pll, pll reset monitor.
    • sstrell's avatar
      sstrell
      It looks like you have incremental compilation enabled for the entire design, locking down the placement and routing. That would prevent you from making a change like this. Check the Design Partitions window.
