GD76
5 years agoFitter Error for fractional PLL
The error in fitting is as follows. Going thorugh the knowledge base, not clear what the solution is. It says "Location FRACTIONALPLL_X0_Y38_N0" already occupied. I can move to different location bu...
- 5 years ago
What device family and Quartus version and edition (Standard, Pro) are you using?
What IP are you using that might be conflicting with the use of a particular PLL?
Have you made I/O pin assignments that might be conflicting?
sstrell
5 years agoWhat device family and Quartus version and edition (Standard, Pro) are you using?
