GD76
5 years agoFitter Error for fractional PLL
The error in fitting is as follows. Going thorugh the knowledge base, not clear what the solution is. It says "Location FRACTIONALPLL_X0_Y38_N0" already occupied. I can move to different location bu...
- 5 years ago
What device family and Quartus version and edition (Standard, Pro) are you using?
What IP are you using that might be conflicting with the use of a particular PLL?
Have you made I/O pin assignments that might be conflicting?
GD76
5 years agoDevice is Cyclone V (5CEFA4F23C7). Quartus Standard version 18.1. There are no IO pin conflict looking thorough the QSF file (attached) The IPs are many DDR2 has pll and NIOS pll, pll reset monitor.
- sstrell5 years ago
It looks like you have incremental compilation enabled for the entire design, locking down the placement and routing. That would prevent you from making a change like this. Check the Design Partitions window.
