13 years agoFitter Added Delay and False Paths
Hi All,
I have a design with a bank of configuration registers, that run to various state machines with different gated or muxed clocks. The reigster outputs are quasi-static, so I don't want to worry about synchronization. I have their output set as false path and my timing reports appear to ignore these paths. However when I look at my fitter report, under "Estimated Delay Added for Hold Timing Details" there is a lot of delay added from these configuration registers that have the false path. Is there any reason why the fitter would do this with the false path added? Any way to get a report of why the fitter added delay? Any other constraint it's meeting that the false path does not guarantee an exception to? Additionally I've been having some issues with minimum pulse widths that I can't get to go away with false paths, perhaps they are related. Thanks in advance.
