Altera_ForumHonored Contributor13 years agoFitter Added Delay and False Paths Hi All, I have a design with a bank of configuration registers, that run to various state machines with different gated or muxed clocks. The reigster outputs are quasi-static, so I don't want ...Show More
Altera_ForumHonored Contributor13 years agoAre you sure the fiter is not adding delay to the *input* of those registers?
Recent Discussionsqsys-generate outputs Info as ErrorInvalid license key (inconsistent authentication code)Timing analysis - long combinational pathRegarding the issue of UFM not startingstarting to learn FPGAs
