14 years ago --- Quote Start --- Not modelsim, but iverilog. The code simulates fine, and generates the correct coefficients (correlated against matlab). Its just the synthesis that chokes. --- Quote End --- I'd be tempted to use iverilog to write out a file with the calculations, and then `include that file for synthesis. You could use a synthesis directive to switch between them, or a `define. A `define might be better, since you can then `include the file in iverilog after the first run has generated it. I know its not the best solution, but sometimes you just have to deal with Quartus the best you can :) Cheers, Dave
