16 years agoNo, there are no deterministic cases that will cause the DC FIFO to fail (except if you try to read from an empty FIFO or write to a full FIFO).
There are stochastic conditions that can cause metastability. You can't do much to avoid them, you can just increase the number of synchronization stages to reduce the probability of a failure to an aceptable level.
