16 years ago --- Quote Start --- If you were to design your own FIFO, *maybe* (and I'm too tired to think properly about this parte) you could come up with a simpler design for a 50/100 MHz case than for a 50/51 MHz case. However, the DC FIFO component assumes nothing about your clocks and always generates a generic component that will *always* work, no matter the case. So, you get the same logic usage for both cases. Of course, if you're using timming driven synthesis you may (or not) see small differences. --- Quote End --- Hi, thanks a lot for the explanation. Then there must be situations when the FIFO cannot guarantee no data loss, right? Do you have any idea what are those cases? I can't really find much useful information from the DC FIFO user guide downloaded from altera website.. thank you
