16 years agoI can't follow your assumption, that there should be a difference between both variants, if you use a FIFO. A 100 MHz data sink can possibly connect to a 50 MHz data source without a FIFO, if the clocks are supplied from a PLL with suitable phase. But with a FIFO, only maximum speed has to be kept.
