12 years ago
Finite state machine - doesnt change state second time & glitch
I have a fairly simple state machine that when in idle state, if txval is high should take the data from input port, put txbus flag to 1, then write it to FT245 chip and when writing is finished and back in idle put txbus back to 0. Until txval is high. If txval was high when entering, it should take the data from input port and so on; or wait until input port data is high.
I am using this state machine from another one, and they share the same clocks. FT245 chip stuff is registered since it is async.
I have noticed 2 things:
In case txval goes high while still in write_end state, txbus drops to 0 and goes high again. I set txbus to 0 only and only in idle state. In all others is it 1.
In case one cycle of state changes is done, it does not go into another cycle of state changes if all conditions for it are satisfied, however it does take the data from input port.
In hardware - in serial terminal I can see this 1 byte being succesfully sent, but nothing else.
I am trying to debug this for quite some time now...but....
https://www.alteraforum.com/forum/attachment.php?attachmentid=8289 https://www.alteraforum.com/forum/attachment.php?attachmentid=8290
Code is:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY FT245 IS
  PORT(
      clk : IN std_logic;
        rstn : IN std_logic;
      txrdy : OUT std_logic;
        txval : IN std_logic;
        txdat : IN std_logic_vector(7 downto 0);
        txbus : OUT std_logic;
      -- FT2232 Bus Signals
        usb_data : inout std_logic_vector(7 downto 0);
        usb_rd_n : out std_logic;
        usb_wr   : out std_logic;
        usb_rxf_n : in std_logic;
        usb_txe_n : in std_logic;
        d_state : out std_logic_vector(2 downto 0)
END FT245;
ARCHITECTURE behv OF FT245 IS
constant CMDDELAY : integer := 10; -- 10*20ns for 50Mhz clock = 200ns
    signal usb_input :  STD_LOGIC_VECTOR (7 DOWNTO 0);
    signal usb_output_next: STD_LOGIC_VECTOR (7 DOWNTO 0);
    signal usb_output_reg :  STD_LOGIC_VECTOR (7 DOWNTO 0);
    signal recv_data_reg  :  STD_LOGIC_VECTOR(7 DOWNTO 0);
    signal recv_data_next  :  STD_LOGIC_VECTOR(7 DOWNTO 0);
   signal rd_n_reg : STD_LOGIC;    -- Registered RD_N (to be written)
   signal rd_n_next : STD_LOGIC;   -- Next RD_N (to be registered)
   signal wr_reg : STD_LOGIC;      -- Registered WR (to be written)
   signal wr_next : STD_LOGIC;     -- Next WR (to be registered)
   signal rxf_reg : STD_LOGIC;     -- Status of RX_F flag
   signal txe_n_reg : STD_LOGIC;      -- Status of TXE_N flag
   signal oe_reg : STD_LOGIC;  -- For Bi-Di bus (to be written)
    signal oe_next : STD_LOGIC; -- For Bi-Di bus (next output enable state - to be registered)
    signal delay_reg : integer range 0 to CMDDELAY;        -- Delay counter (for start next state)
   signal delay_next: integer range 0 to CMDDELAY;        -- Delay counter (for start next state)
    -- Build an enumerated type for the state machine
    type state_type is (init, idle, write_prepare, write_strobe, write_end);
    -- Register to hold the current state
    signal state_now : state_type;
    signal state_next : state_type;
begin
  --{ Params  : <CLK>  Clock
  --{           <RST>  Reset
  --{ Descript: State machine: State register
  --{           The state register is updated
  --{           Using synchronuous reset
  process (clk, rstn)
  begin
    if (rising_edge(clk)) then
      if (rstn = '0') then
        delay_reg <= 0;
      else
        if (delay_reg = 0) then
          state_now <= state_next;
          delay_reg <= delay_next;
        else
          delay_reg <= delay_reg - 1;
        end if;
      end if;
        IF(state_now = init) THEN
           d_state <= "000";
        ELSIF(state_now = idle) THEN
           d_state <= "001";
        ELSIF(state_now = write_prepare) THEN
           d_state <= "010";
        ELSIF(state_now = write_strobe) THEN
           d_state <= "011";
        ELSIF(state_now = write_end) THEN
           d_state <= "100";
        ELSE
           d_state <= "111";
        END IF;
    end if;
  end process;
  --{ Descript: State machine: Output buffer
  --{           The output registers are updated
  process (clk)
  begin
       rd_n_reg <= rd_n_next;  -- Register RD_N output
        wr_reg <= wr_next;      -- Register WR output
        rxf_reg <= usb_rxf_n;   -- Register RXF input
        txe_n_reg <= usb_txe_n; -- Register TXE_N input
        oe_reg <= oe_next;      -- Register Bi-Di OE flag
        recv_data_reg <= recv_data_next;
       usb_output_reg <= usb_output_next;
    end if;
  end process;
 txrdy <= not txe_n_reg; -- assert txrdy when FIFO has space.
  --{ Params  : <START>       Start flag
  --{           <RST>         Reset
  --{           <state_now>   Current state
  --{ Descript: State machine: Next state logic
  --{ Notes   : <delay_next> is the delay after the -next- state has been executed
  --{           and must be reset
  process (clk, rstn, state_now, txval, txdat, rd_n_reg, wr_reg, oe_reg, delay_reg, usb_output_reg, recv_data_reg, txe_n_reg)
  begin
       rd_n_next <= '1';
        wr_next <= '0';
        oe_next <= '1'; -- default in output bus
        usb_output_next <= (others=>'0');
        recv_data_next <= (others=>'0');
      delay_next <= 0;
        state_next <= init;
      txbus <= '1';
    else
       rd_n_next <= rd_n_reg;
        wr_next <= wr_reg;
        oe_next <= oe_reg;
        delay_next <= delay_reg;
        state_next <= state_now;
        usb_output_next <= usb_output_reg;
        recv_data_next <= recv_data_reg;
        txbus <= '1';
      case state_now is
        when init   =>
                                rd_n_next <= '1';
                                wr_next <= '0';
                                delay_next <= 0;
                        state_next <= idle;
                               txbus <= '0';
          when idle =>
                       delay_next <= 0;
                     IF(txval = '0') THEN
                                txbus <= '0';
                            ELSIF(txval = '1') THEN
                                state_next <= write_prepare;
                                usb_output_next <= txdat;
                                txbus <= '1';
                            END IF;
          when write_prepare =>
                          txbus <= '1';
                      if(txe_n_reg = '0') then -- wait until TX fifo has space
                            oe_next <= '1';
                            delay_next <= 0;
                            state_next <= write_strobe;
                          end if;
        when write_strobe =>
                          txbus <= '1';
                    wr_next <= '1';
                        delay_next <= CMDDELAY;
                        state_next <= write_end;
          when write_end =>
                      txbus <= '1';
                    wr_next <= '0';
                          state_next <= idle;
          when others =>
                          wr_next <= wr_reg;
                          oe_next <= oe_reg;
                          state_next <= init;
                          delay_next <= 0;
                          txbus <= '0';
      end case;
    end if;
end process;
  --{ Descript: Output
  --{           The actual outputs are set
  usb_rd_n <= rd_n_reg;
  usb_wr   <= wr_reg;
  usb_data <= usb_output_reg when oe_reg = '1' else (others => 'Z');
  usb_input <= usb_data when oe_reg = '0';
END behv;
    Attached is a new code which works :)
    Thanks for your help & feedback.
    I have also cleaned up the code since I implement now single process delayed state machine; so I do not need to register outputs separately as before but I update them in the FSM.
    Inputs from the chip are registered though in a separate process.
    I use this on Wayengineer Cyclone IVE FPGA board and I have tested it with another code that uses buttons to update 7-segment display and also sends current data there to the PC over USB. If someone wants, I can provide that code as well.
    Next step would be reading from USB and notifying...
    LIBRARY ieee;
    USE ieee.numeric_std.all;
    ENTITY FT245 IS
      PORT(
          clk : IN std_logic;
            -- debug
            -- d_delay_reg : out std_logic_vector(3 DOWNTO 0); -- debug only
            -- d_state : out std_logic_vector(2 downto 0); -- debug only
    END FT245;
        signal usb_output :  STD_LOGIC_VECTOR (7 DOWNTO 0);
       signal rd_n : STD_LOGIC;    -- RD_N (to be written)
       signal wr : STD_LOGIC;      -- WR (to be written)
       signal oe : STD_LOGIC;  -- For Bi-Di bus (to be written)
    begin
      process (clk)
      begin
        end if;
      end process;
     PROCESS(clk, rstn, txval, txdat, rd_n, wr, oe, usb_output, txe_n_reg, rxf_reg)
        VARIABLE  state_now : state_type;
        VARIABLE  state_next : state_type;
        -- Counters to implement state change delays
        VARIABLE  currCnt : UNSIGNED(3 DOWNTO 0);
        VARIABLE  cnt  : UNSIGNED(3 DOWNTO 0);
        CONSTANT  DELAY : UNSIGNED(3 DOWNTO 0) := "1010";
     BEGIN
       IF(rstn = '0') THEN
           cnt := (others => '0');
            state_now := init;
            state_next := init;
            rd_n <= '1';
            wr <= '0';
            oe <= '1'; -- default in output bus
            usb_output <= (others=>'0');
          txbus <= '1';
        ELSIF(rising_edge(clk)) THEN
          CASE state_now IS
                  when init =>
                                rd_n <= '1';
                                wr <= '0';
                                txbus <= '1';
                                state_next := idle;
                    when idle =>
                                    txbus <= '0';
                                    state_next := write_prepare;
                                    usb_output <= txdat;
                                    txbus <= '1';
                                END IF;
                                    oe <= '1';
                                    state_next := write_strobe;
                              end if;
                             wr <= '1';
                                cnt := DELAY;
                                state_next := write_end;
                    when write_end =>
                                wr <= '0';
                                state_next := idle;
                    when others =>
                             state_next := init;
            END CASE;
            -- handle delay between change states
            currCnt := currCnt + 1;
            IF(currCnt >= cnt) THEN
              state_now := state_next;
              currCnt := (others => '0');
            END IF;
            -- debug only
            -- IF(state_now = init) THEN
            --   d_state <= "000";
            -- ELSIF(state_now = idle) THEN
            --   d_state <= "001";
            -- ELSIF(state_now = write_prepare) THEN
            --    d_state <= "010";
            -- ELSIF(state_now = write_strobe) THEN
            --   d_state <= "011";
            -- ELSIF(state_now = write_end) THEN
            --    d_state <= "100";
            -- ELSE
            --   d_state <= "111";
            -- END IF;
            -- d_delay_reg <= std_logic_vector(cnt); -- debug only
       END IF;
     END PROCESS;
      usb_rd_n <= rd_n;
      usb_wr   <= wr;
      usb_data <= usb_output when oe = '1' else (others => 'Z');
      usb_input <= usb_data when oe = '0';
    END behv;
    --- Quote Start ---
    But it has glitches on the txbus output, as Kaz mentioned. All signals should be synchronous - but txbus is asynchronous.
    2 process state machines have fallen out of favour in recent times, for this reason (async outputs). The single process state machine is now favoured.
    --- Quote End ---
    I have implemented it as a single process FSM now, without reading your post. Code is simpler, shorter and easier to understand. Plus yes - output like txbus changes only on clk edges.
