10 years ago
finding single max value in an input signal having 1000 decimal values
I want to find max in input file, read from a memory. This input file size 1000 decimal sample values. I have written the following code to find max value but it didn't give the correct result .plzzz help me so i can find a single max value in this input signal..thanks in advance..
module max_min(input clk, input [15:0]din, output [15:0]dout); reg [15:0]max=0;
always @(posedge clk)
begin
if($signed(din)>max)
max<=din;
else
max<=0;
end
assign dout=max;`endmodule
    Why do you assign 0 to max in the "else" part? You should keep the current value of the max register instead.
    --- Quote Start ---
    --- Quote End ---
    dear Daixiwe tanks for time..oky.this may be one problem..but i want that my code should output a single max vlaue an input array of 1000 values which is read from a mem file..will u modify my code so i can get single max value among these 1000 values?
    --- Quote Start ---
    plzzz help me out..i m in a disparate situation
    --- Quote End ---
    People here will not write code for you. we are here to help you fix YOUR code, not provide code for you.
