10 years agofinding single max value in an input signal having 1000 decimal values
I want to find max in input file, read from a memory. This input file size 1000 decimal sample values. I have written the following code to find max value but it didn't give the correct result .plzz...
10 years ago --- Quote Start --- plzzz help me out..i m in a disparate situation --- Quote End --- People here will not write code for you. we are here to help you fix YOUR code, not provide code for you.
