10 years agofinding single max value in an input signal having 1000 decimal values
I want to find max in input file, read from a memory. This input file size 1000 decimal sample values. I have written the following code to find max value but it didn't give the correct result .plzz...
10 years ago --- Quote Start --- Why do you assign 0 to max in the "else" part? You should keep the current value of the max register instead. --- Quote End --- dear Daixiwe tanks for time..oky.this may be one problem..but i want that my code should output a single max vlaue an input array of 1000 values which is read from a mem file..will u modify my code so i can get single max value among these 1000 values?
