9 years agoFile not simulating with ModelSim-Altera
Hello guys, I have the following two projects. The first one Simulates perfectly in modelsim-altera, but the second one does not show output. I want to know where is the problem in the second one??? ...
9 years agoDo not mix in your design registers clocked from falling and rising edges except you are implementing DDR registers. If you are using single edge use only risig edge.
--- Quote Start --- Now, do you think I could extend your code to divide by (4,6,8,......)??? Thank you for your help really. --- Quote End --- Yes you can. Add counter which is incremented every clock cycle. Toggle clk_div signal when counter reaches certain amount (depends on divide by value), reset counter.
