9 years agoFile not simulating with ModelSim-Altera
Hello guys, I have the following two projects. The first one Simulates perfectly in modelsim-altera, but the second one does not show output. I want to know where is the problem in the second one??? ...
9 years agoHi,
I think there is something with output port type declared as a buffer. I never use ports declared as a BUFFER. Use signals and assign them to output ports. I would change your code to something like this:---------------------- Frequency division by 2 -------------------
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY freq_div2 IS
PORT (
clk : IN STD_LOGIC;
reset_n : IN STD_LOGIC;
out2 : OUT STD_LOGIC);
END freq_div2;
ARCHITECTURE example OF freq_div2 IS
signal clk_div : std_logic;
BEGIN
PROCESS (clk, reset_n)
BEGIN
IF reset_n='0' THEN
clk_div<='0';
IF (clk'EVENT AND clk='0') THEN
clk_div<= NOT clk_div;
END IF;
END PROCESS;
out2<=clk_div;
END example; By the way why is yor process trigered from falling clock edge?
