15 years ago
FFT megaCore usage problem
I am using FFT megaCore as the core of my digital spectrum analyzer
FFT core paramters: N=64, streaming mode, 8 bit inputs and output.
However, in the vector waveform file that I made the simulation on FFT megaCore, the source real and imaginary have noise and I just want to capture the output at negative edge of the clock because those values are stable values that I wanted.
I think of using negative edge-triggered D-Flip flop to store value when at the negative-edge of clock by using the source_sop and source_eop to enable the the D-flipflop. but that 2 signal only peaks for a short time.
May I know how can I use this 2 signals to enable the D-flipflop or is there any better way to capture stable values from FFT megaCore?
    The source_sop and source_valid are not rising at the same time, this problem I also didnt know why this happens like this, These 2 signals are controlled by the control unit (CU.vhd). Could you please take a look on my CU.vhd file?
    Sorry for the delay of answer, I was quite busy with the work.
    I test your project, and I don't get the same problem as you. So I think the problem comes from the waveform file you defined.
    I attach the result of simulation (I put manually random value for the inputs), and the waveform input file I used. Maybe try with this file to check that you have something working well. Then check with your waveform file what is wrong. You can also send your waveform file, I can look at it.
    Hi, thanks for you reply.
    I have run again the vwf you provided but I cant get the same simulation as yours. This simulation result I attached as the fft_h_resimulate.vwf. The sink_valid and sink_sop cant rise at the same time as compared to your original simulation, it seems like there is delay in my simulation and there are noise just at the rising edge of clock for output value sink real and imaginary.
    I also attached my previous simulation. The input value is a 1kHz sine wave that I get it from Matlab but I key in manually in the waveform editor. Hope you can find the problem for my simulation.
    I really don't understand how you get these results. I take the vhd files you provided, and use the wvf and I have no problem. I try also with your waveform file and I don't have problem.
    The simulation mode you use is it "functionnal" (Menu "Processing" -> "Simulator Tool") ?
    Else I would advise you to create your test bench file and use ModelSim instead of the Quartus Simulator.
    I am using "Timing" mode in the Simulator Tool there... Is it because I did the simulation in timing mode that result in all these random value or noise?
    I would like to ask in my control unit, I would like to control the source_ready signal where this signal is '1' when the data_real is available and '0' when the data_real is not available
    Can I do the coding like this?
    if(data_real) then
    source_ready<='1';
    else
    source_ready<='0';
    end if;
    in my vhdl code of CU.
    So try to simulate with the functionnal mode to see if it works as you want.
    Normally, what you check with the simulation is the functionnal behaviour, and the timing violation are checked by Quartus with the TimeQuest tool.
    About your question for generating source_ready, you cannot do what you propose directly. If you want what you can do is to put data_real to "XXXXXXXX" when there is no data, and then make the following test
    if (data_real = "XXXXXXXX") then
        source_ready <= '0';
    else
        source_ready <= '1';
    end if;
    But this kind of things works for simulation, not synthesis.
    I would like to ask about the reading of output
    I am using Nios2 to design my c file to read the output from the fft core of my design...
    I am combining the fft output 8 bit source_real, 8 bit source_imag and 6 bit source_exp into 1 22-bit signal output_int..
    I am using the command IORD to read my 22-bit signal into an array in c and i declared the array as alt_32 output[64];
    Now I would like to use separate the combined into its original 3 parts.. So, may I know how I can separate the combined signal back to its 3 individual signal of 8bit, 8 bit and 6bit?
    I see two ways to do it. Either you can use three addresses to access the FFT results, so you have something like this in your C code :
    real = IORD(FFT_BASE, REAL_REG);
    imag = IORD(FFT_BASE, IMAG_REG);
    exp = IORD(FFT_BASE, EXP_REG);
    Or, you can use one address and separate the data in the C code like this :
    data = IORD(FFT_BASE, DATA_REG);
    real = (data >> 14) & 0xFF;
    imag = (data >> 6) & 0xFF;
    exp = data & 0x3F;
    Is this answer your question ?
    Hi, I am very new to the usage of this FFT Megacore function.
    I recently just wanted to try out this FFT Megacore function to see how it works.
    I tested the testbench file provided by LETS. I encountered error messages upon running the file in Quartus II. May I know if there is a recent update of it? Pardon me, I am very new in this and am interested to learn (I only have basic vhdl knowledge). Any help will be much appreciated.
