I would like to ask about the reading of output
I am using Nios2 to design my c file to read the output from the fft core of my design...
I am combining the fft output 8 bit source_real, 8 bit source_imag and 6 bit source_exp into 1 22-bit signal output_int..
I am using the command IORD to read my 22-bit signal into an array in c and i declared the array as alt_32 output[64];
Now I would like to use separate the combined into its original 3 parts.. So, may I know how I can separate the combined signal back to its 3 individual signal of 8bit, 8 bit and 6bit?
