17 years agoDoes TimeQuest use it in it's analysis? Yes, so all analysis is correct.
Does the PLL compensate for it? No, so the the clock will be delayed in time and will suffer the PVT variation of that global. Naturally, it is suggested to drive the PLL directly with one of its dedicated clock pins. But there are plenty of cases where you have to drive it with a global and it works out all right.
