Fatal Error: Unhandled exception when starting quartus GUI in linux (21.1)
When I try to start Quartus in 21.1 standard, the program crashes;
I am working in linux.
Can anybody tell me what error that can cause this failure ?
I had no problem with this yesterday, but today I do not seem to be able to open the gui.
It seems like qsys is working properly (started stand-alone).
What I do;
quartus &
result:
*** Fatal Error: Unhandled exception
0x8286: ERR_STACKWALKER::get_stack_trace(void const**, int, int, void*) + 0xd8 (ccl_err)
0xb535: err_terminator() + 0x5a (ccl_err)
0x82ae6: __cxxabiv1::__terminate(void (*)()) + 0x6 (jtag_client)
0xb3ef: err_sigaction_handler + 0x7a (ccl_err)
0xcae6f: qt_memfillXX_avx2(unsigned char*, long long __vector(4), long long) + 0x8f (Qt5Gui.so.5)
0x10b065: qt_rectfill_argb32(QRasterBuffer*, int, int, int, int, QRgba64 const&) + 0x75 (Qt5Gui.so.5)
0x3b08bb: fillRect_normalized(QRect const&, QSpanData*, QRasterPaintEnginePrivate*) [clone .constprop.183] + 0x23b (Qt5Gui.so.5)
0x3b19fa: QRasterPaintEngine::fillRect(QRectF const&, QSpanData*) + 0x30a (Qt5Gui.so.5)
0x3d1de2: QPainter::fillRect(QRect const&, QBrush const&) + 0xd2 (Qt5Gui.so.5)
0x190ee2: QWidgetPrivate::paintBackground(QPainter*, QRegion const&, QFlags<QWidgetPrivate::DrawWidgetFlag>) const + 0x432 (Qt5Widgets.so.5)
0x193f0f: QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, QFlags<QWidgetPrivate::DrawWidgetFlag>, QPainter*, QWidgetRepaintManager*) + 0xb6f (Qt5Widgets.so.5)
0x16ab73: QWidgetRepaintManager::paintAndFlush() + 0x1093 (Qt5Widgets.so.5)
0x16bcbf: QWidgetRepaintManager::sync(QWidget*, QRegion const&) + 0x2cf (Qt5Widgets.so.5)
0x1b721a: QWidgetWindow::handleExposeEvent(QExposeEvent*) + 0xda (Qt5Widgets.so.5)
0x1b7e23: QWidgetWindow::event(QEvent*) + 0x413 (Qt5Widgets.so.5)
0x15bebc: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0x9c (Qt5Widgets.so.5)
0x162f20: QApplication::notify(QObject*, QEvent*) + 0x220 (Qt5Widgets.so.5)
0x2bff40: QCoreApplication::notifyInternal2(QObject*, QEvent*) + 0x110 (Qt5Core.so.5)
0x1490b1: QGuiApplicationPrivate::processExposeEvent(QWindowSystemInterfacePrivate::ExposeEvent*) + 0xa1 (Qt5Gui.so.5)
0x14933d: QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) + 0x1cd (Qt5Gui.so.5)
0x1236cb: QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0xbb (Qt5Gui.so.5)
0x64ec3: QXcbUnixEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0x23 (Qt5XcbQpa.so.5)
0x2be7aa: QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 0x11a (Qt5Core.so.5)
0x355ca7: QDialog::exec() + 0x1b7 (Qt5Widgets.so.5)
0x16ca77: AFCQ_MSG_DISPLAY::internal_error_display(std::string) + 0x2d3 (gcl_afcq)
0x4923d: MSG_REPORT::internal_error(std::string const&) + 0x155 (ccl_msg)
0x651b5: MSG_ERROR_INFO::finalize() + 0x5f (ccl_msg)
0x6542d: MSG_INTERNAL_ERROR::report_fatal(char const*, void*) + 0x6b (ccl_msg)
0xb1ae: err_report_fatal_exception(char const*, void*) + 0x75 (ccl_err)
0xb4ad: err_sigaction_handler + 0x138 (ccl_err)
0xcc318: qt_memfill32_avx2(unsigned int*, unsigned int, long long) + 0x8 (Qt5Gui.so.5)
0x3b1985: QRasterPaintEngine::fillRect(QRectF const&, QSpanData*) + 0x295 (Qt5Gui.so.5)
0x190cd2: QWidgetPrivate::paintBackground(QPainter*, QRegion const&, QFlags<QWidgetPrivate::DrawWidgetFlag>) const + 0x222 (Qt5Widgets.so.5)
0x16abf0: QWidgetRepaintManager::paintAndFlush() + 0x1110 (Qt5Widgets.so.5)
0x2c7f77: QCoreApplication::exec() + 0x97 (Qt5Core.so.5)
0x1f2b: qgq_main(int, char const**) + 0x7b (quartus)
0x3ee30: msg_main_thread(void*) + 0x10 (ccl_msg)
0x5acc: thr_final_wrapper + 0xc (ccl_thr)
0x3eeef: msg_thread_wrapper(void* (*)(void*), void*) + 0x62 (ccl_msg)
0x9f9c: mem_thread_wrapper(void* (*)(void*), void*) + 0x5c (ccl_mem)
0x91d9: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x5b0f: thr_thread_wrapper + 0x15 (ccl_thr)
0x40ea1: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xb2 (ccl_msg)
0x2011: main + 0x26 (quartus)
0x22555: __libc_start_main + 0xf5 (c.so.6)
Exiting...
- HubertG
Contributor
Hi annekri,
Sorry to hear the bad experience you are currently facing. Before we proceed further debugging, can I request the information of the Ubuntu version of your Linux machine, is it version 22.04 ?
Unfortunately and to be frank, Quartus Prime Standard 21.1 Edition is not supported on Ubuntu with 22.04 version. (Picture and website link as below for your reference)
Therefore, here's another workaround for you. You may want to download Quartus Prime Standard with 22.1 version or higher in order for you to run smoothly.
I think this might be able to solve your problem. Please do not hesitate to ask me if you have further inquiries. Do also let me know if this solution works for you
Best Regards
Hubert
- HubertG
Contributor
Hi annekri,
May I know is the solution provided above solved your problem ?
Hubert
- HubertG
Contributor
Hi annekri,
How's everything, is it going well ? ^-^
Hubert
- HubertG
Contributor
