13 years ago
fast io assignment ignored
I used a fast io assignment for my input and output flops
and it got ignored in the fitter (listed as such in the fitter report)
I am guesing this is because of using a global clock to clock the io register?
(I am using fast io register to meet timing along a path and regular flops clock to q
seems high)
Is there a way I can use Fast IO and clock it by a global clock (clock is output of PLL and getting distributed on a global clock line)
    All fast I/O can be driven by a global, and in most designs, are driven. The most common reason I've seen is that there's logic between the register and the I/O cell. (Check Technology Map Viewer, not just your RTL, to see if something got synthesized differently than expected).
    hi rysc, it is a direct connecttion to the I/O (e.g. register driving output or driven by input)
    I will double check. I wish the tool would say why it ignored it.
