17 years agofalse path?
I've got an internally generated page signal which changes state every few thousand clocks and the timing isn't particularly important. Am I best to treat this as a false path or use some form of multicycle constrain in TimeQuest. If it's the latter please could you state which multi-cycle exception I should use as it is really confusing - I will read up in the mean time. Thanks, D.
