17 years ago
False Path settings in .qsf file
Hello All,
I am using Altera Max700AE CPLD device for my design. In my design I have two clocks one with 45 Mhz and another with 4 Mhz.
1) I can not able to set setup and clock to out settings fro each clock
2) I want to exclude one path which I know it will not meet the timing as the synchronized outputs are used as input to some on nand gates and multiplexers to generate final output, I can not able to do exclusion of path (false paths)
I am using clasic timing analyser. Timequest anylser is not supported for this device.
And all my constraints are presented in .qsf file.
I have tried wih the command set_false_path.
I have tried set_timing_cut_assignment.
Can any body help me out in resolving this issue.
best regards,
Pavan M
