8 years agoFalse path question - internal counter bit vs FSM state bit
Dear Altera Forum members... This is my first post here :) I have a sub-circuit that consists of a binary up-counter (LPM_counter) with asynchronous reset and count enable, and a comparator (LP...
8 years agoThe project uses the MAX V 5M80ZM64I5 device.
There are three auto-generated VHDL files: lpmcompare.vhd, lpmcounter.vhd and lpmzerotimeflag.vhd. The lpmcountandcompare.vhd, connects them together as a subcircuit. The toplevel entity is the timingtest_lpmcc_minifsm.vhd. The .sdc file is called timingTest_LPMcc_miniFSM (there is only one constraint, the "create_clock"...) Recall that Quartus by default uses 3-space wide tabs, such that the text-files may not look that nice in other text-editors...
