8 years agoFalse path question - internal counter bit vs FSM state bit
Dear Altera Forum members... This is my first post here :) I have a sub-circuit that consists of a binary up-counter (LPM_counter) with asynchronous reset and count enable, and a comparator (LP...
8 years ago --- Quote Start --- Dear Altera Forum members... This is my first post here :) I have a sub-circuit that consists of a binary up-counter (LPM_counter) with asynchronous reset and count enable, and a comparator (LPM_compare). The sub-circuit compares an input 5-bit vector to the count value and sets an output flag if the count value is greater-or-equal to the input data value. This flag is used as a control bit to a finite state machine. When running the TimeQuest timing analyzer tool in Quartus, I get setup timing violations with worst-case timing paths that involve the q[1]-bit and states of the FSM. My question is whether or not I can set these as false paths https://alteraforum.com/forum/attachment.php?attachmentid=14298&stc=1 The figure shows how the TimeQuest labels the nodes that violate the setup timing. I was thinking that since the timing violations does not involve the flag used to control the state transitions, I can set the shown paths as false paths... Please comment. Regards Ronny --- Quote End --- Every path is relevant unless you the designer knows that it is not. Your clock is 50 MHz and in a modern fpga you shouldn't fail timing. likely you are clocking wrong. Or too long comb section
