GNote's avatar
GNote
5 years ago
Failure to generate companion license for Modelsim-Altera
I am trying to generate a companion license for my home computer by opening the window "Generate Companion/Temporary Check-out Licenses". However, every time the hostid in the generated license file points to my primary computer, not the companion ID specified on the web page.
Here is the diagnostic I get from the license management tools:
================================== begin
Diagnostics
FlexNet diagnostics on Fri 3/27/2020 13:09
License file: C:\altera\15.0\license.dat
"alteramtivsim" v2021.03, vendor: mgcld uncounted nodelocked license, locked to ethernet address "8851fb6b4d2e" starts: 27-mar-2020, expires: 27-mar-2021
This license cannot be checked out because: Invalid host.
The hostid of this system does not match the hostid specified in the license file.
Feature: alteramtivsim
Hostid: 8851fb6b4d2e - this is the hostid of the primary computer
License path: C:\altera\15.0\license.dat;
FlexNet Licensing error:-9,57
================================== end
My companion hostid is nowhere to be found in the license file.
  • AR_A_Intel's avatar
    AR_A_Intel
    could you provide the latest license.dat file that you generate and also the NICID for the companion license.
  • GNote's avatar
    GNote
    You already requested this information and I provided it in one of the messages above. Here I do copy & paste from the previous message:
    1. Companion NIC ID is 000C29821BD7
    2. Machine OS is Windows 7
    3. Here is the license file
    ======================================================== license file begins
    # Intel Corporation Software and/or Intellectual Property License File
    # Issued 27 March 2020
    # Upgrade to these products will no longer be available after the Maintenance Expiration
    # date unless licenses are renewed.
    # Fixed Node License
    # Primary Machine Name-GN_WIN7_2015
    # Primary Machine ID-NIC ID 8851FB6B4D2E
    # Companion ID-NIC ID 84A93E60A2E0
    # Companion ID 2-NIC ID 000C29821BD7
    # Product License Summary:
    # ModelSim Intel FPGA Edition Software, 1 Seat(s)
    # - Maintenance Expiration of 2016.11
    # - License Expires 27-Mar-2021
    # FEATURE START
    # The following is a license file for the ModelSim
    # Number of seat licenses is 1
    # License Expires 27-Mar-2021
    INCREMENT alteramtivsim mgcld 2021.03 27-mar-2021 uncounted \
    FF40057B5E9DD762320F \
    VENDOR_STRING=6FB5F269 HOSTID=8851fb6b4d2e ISSUER=Intel SN=71038913 \
    SIGN2="1813 C9D6 4DEF B1A4 5D69 2009 66C6 0E36 79C8 428E 3006 7EBC \
    611D 3969 0EF3 05D9 D129 60C8 75F6 3464 A6F9 046D 5150 2FF5 1423 57A4 \
    1E5E C753 D558 6C18"
    # FEATURE END
    # End of Intel Corporation Software and/or Intellectual Property License File. Issued 03/27/2020
    ======================================================== license file ends
  • DamBam's avatar
    DamBam
    Hello @GNote and @AR_A_Intel ,
    Could You please share the solution to this issue?
    I have the same issue as only primary ID station can run Intel-Modelsim normally ;(
    Thanks in advance
