12 years ago
Failiure to create BFM testbench for ip cores
It's the first time that I'm trying to use the BFMs so I decided to try and simulate the PIO or SPI IP cores that come with Qsys.
I used the tutorial on the User Guide Avalon Verification IP Suite to simulate the FIFO and it worked and now I'm trying to do the same with those cores.
I added the PIO core and exported all the interfaces and tried to generate a verilog testbench with standard BFMs.
I'm getting an error saying that Error: pio-32BITS_inst_spi_0_spi_control_port_bfm.m0: master without waitrequest must match parameters and ports of slave pio-32BITS_inst.spi_0_spi_control_port.
and when I try to generate the testbench for the SPI core I get the same error and an additional error saying Error: pio-32BITS_tb.pio-32BITS_inst_spi_0_spi_control_port_bfm.m0: pio-32BITS_inst.spi_0_spi_control_port (0x0..0x1f) is outside the master's address range (0x0..0xf).
What am I doing wrong? I thought the generation would be able to deal with a slave that doesn't have a waitrequest signal and I'm really not sure what to do with the second error.
Thanks in advance,
Chen
    How can you change the parameters of the master BFM if it's being generated by QSys?
