Failing IO buffer
Hi Ken,
as stated, the code doesn't work for EEPROM. After a byte write, page data is written to nonvolatile memory after 150 us of write inactivity. Page write takes typically 2 ms, review AT28C64B datasheet. You'll need to wait for end of page write to be able to reread written data.
Regarding PLL, Clk16MHz.qip and Clk16Mhz.v or *.vhd are missing.
Frank
- KenBee9 months ago
Hello again, Having read the EEPROM data sheet, I read it as only doing a page write if a subsequent word is presented within 150us of the first. In my case i only write one byte so there should only be one write cycle lasting for 100ns. The results I get confirm that the write and read are both successful and that the read data travels through the IO buffer correctly. I see no reason for the receiving instance should not read the incoming data but that is what is happening. Hence this plea for help.
Regarding the clock, the only choices available are the .cmp, .irc and_inst.vhd files. (I am using Q13.1). I can rebuild the clock if necessary but would that help in this instance?
Ken
- FvM9 months ago
Hi Ken,
how do you verify that "the write and read are both successful and that the read data travels through the IO buffer correctly". According to AT28C64B datasheet, the device won't replay written data before internal copy to nonvolatile memory has finished. It even doesn't reflect previous EEPROM content but sends toggle bit and data polling info on two data lines (IO6 and IO7).
PLL *.qip and HDL files are generated by PLL MegaWizard in any Quartus version. .qip may link to a subfolder but at least Clk_16MHz.qip is located in your projects project folder, look into base_top.qsf.
Frank- KenBee9 months ago
I use an oscillosope to verify all signals. I stop the instance from running (FSM 'Spin') and check the data pins on the EEPROM, the pins on the FPGA - DataIn bus, and the output DataCheck. The DataIn bus reads correctly, so I know the buffer is passing the data from EEPROM correctly. But the DataCheck, which should be a copy of the DataIn bus, is all highs.
As an aside, I changed the write time to 10ms but it has made no difference.
Ken
