Failed to start in Programmer
- 3 years ago
Could you please go through the steps provided in the user guide and check if there is any configuration or device compatible issue?
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
I noticed that your project has selected the device "Stratix 10:1ST280EY2F55E1VG." Could you please try cleaning the project (Project > Clean Project) and then recompiling it?
Also, I'd like to ask if you might be using the old .sof file that was generated for the previous device by any chance?
Richard Tan
- Junyong3 years ago
Thank you, Richard.
I'm tyring to compile the project after cleaning it.
By the way, I have a question regarding the JTAG ID code.
When I program the project, I got a message that "Cant' configure deivce. Expected JTAG IC code 0x4321D0DD for device2, but found JTAG ID code 0x323D0DD. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the chain description file (.cdf)."
Honestly, I have no idea how to handle above issue.
- FvM3 years ago
your latest posts suggests that you are trying to program the wrong device in JTAG chain, MAX V rather than Stratix 10. Although it should be able to select the correct device in programmer, I suggest to remove MAX V from device chain by respective DIP switches. User manual tells how.- Junyong3 years ago
Thank you for your reply.
After removing the MAX V from the device chain, I tried to program the project again.
I had a message that File "Generated .sof" is incomplete - Power management settings are not set up appropriately on VID part.
So, should I modify the power management setting? I have no idea why this happend, becuase I just downloaded, compiled, and programmed the example PAR file on my dev kit.
