Failed to start in Programmer
- 3 years ago
Could you please go through the steps provided in the user guide and check if there is any configuration or device compatible issue?
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
Richard Tan
- Junyong3 years ago
Hi Richard,
I'm stil trying to resolve above issue.
My device is Intel® Stratix® 10 TX Signal Integrity Development Kit.
The example design file is Stratix10_PCIeGen3x8_DMA_18_0.
After compilation, I'm trying to go further at "Programmer" stage.
When I clicked "Auto Detect", then pop-up says I should select my device from the list below.
I think my device is not here, so what should I do to select my device correctly?
- FvM3 years ago
according to user guide, the Stratix 10 device is 1ST280EY2. The programmer however doesn't care for speed code, so any of the three selections should work. More important that the correct device is select in your project, can be expected for examples shipped with board.- Junyong3 years ago
Thank you for your reply, FvM.
After selecting the device "1ST280EY2", I have a pop-up warning with the message below:
I'm wondering why the message showed up. I already modify the Instance with Stratix 10:1ST280EY2F55E1VG. But, the compiled stuff has the device of 1SX280LU3F50S1.
Can I know how to change the device name in the project?
