16 years ago --- Quote Start --- Thanks, I suppose the fitter place and route the design and then there is the timing analisys. If I have for example 100 failed paths the one routed is included in these 100 or the one routed is ok and there are other 100 paths failed? I am using the classic analyzer. Best regards. Stefano --- Quote End --- Hi Stefano, the timing analysis is done for all paths in your design. You can set the number of reported signals for the timing analyzer. The default is 100. All pahts which violates the requirement are marked in red. BTW: you should get an info in the message window about the number of failing paths. Kind regards GPK
