13 years agoexternal memory interface toolkit failure
FWIW, the external memory interface toolkit appears to have an uncaught exception as follows (on Ubuntu 12.04.1 Linux). There are also some Linux processes left behind (see ps output below) which have to be killed before any quartus tool that uses the system console, such as the programmer or the EMIT, can be reused. This problem can become somewhat vexing because it takes the EMIT some time to start, and then one has to start over again whenever experiencing this issue again.
Internal Error: Sub-system: RDB, File: /quartus/db/rdb/rdb_table.cpp, Line: 1797 m_valid_max < m_window_max Stack Trace: 0x7dc29: RDB_TABLE_DATA_VALID_WINDOW_ELEMENT::get_svg() const + 0x2b3 (db_rdb) 0x58752: RPWQ_TABLE::add_item(RDB_TABLE_OBJECT*, int, QStandardItem*, int) + 0xa42 (resr_rpwq) 0x58b8c: RPWQ_TABLE::add_item(RDB_TABLE_OBJECT*, int, QStandardItem*, int) + 0xe7c (resr_rpwq) 0x58b8c: RPWQ_TABLE::add_item(RDB_TABLE_OBJECT*, int, QStandardItem*, int) + 0xe7c (resr_rpwq) 0x5938b: RPWQ_TABLE::load_rdb_table(RDB_OBJECT*) + 0x54f (resr_rpwq) 0x5a605: RPWQ_PAGE_CONTAINER::open_table_type(RDB_OBJECT*) + 0xa3 (resr_rpwq) 0x6a6a5: RPWQ_PAGE_CONTAINER::open_page(QString const&) + 0x309 (resr_rpwq) 0x6a8d0: RPWQ_PAGE_CONTAINER::qt_metacall(QMetaObject::Call, int, void**) + 0x86 (resr_rpwq) 0x17fd53: QMetaObject::metacall(QObject*, QMetaObject::Call, int, void**) + 0x53 (QtCore.so.4) 0x190064: QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 0x274 (QtCore.so.4) 0x30d77: RPWQ_REPORT_TOC_VIEW::request_to_open_page(QString const&) + 0x45 (resr_rpwq) 0x31dc4: RPWQ_REPORT_TOC_VIEW::on_clicked(QModelIndex const&) + 0x232 (resr_rpwq) 0x61c24: RPWQ_REPORT_TOC_VIEW::qt_metacall(QMetaObject::Call, int, void**) + 0x108 (resr_rpwq) 0x17fd53: QMetaObject::metacall(QObject*, QMetaObject::Call, int, void**) + 0x53 (QtCore.so.4) 0x190064: QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 0x274 (QtCore.so.4) 0x7002a3: QAbstractItemView::clicked(QModelIndex const&) + 0x43 (QtGui.so.4) 0x70f980: QAbstractItemView::mouseReleaseEvent(QMouseEvent*) + 0x150 (QtGui.so.4) 0x75638c: QTreeView::mouseReleaseEvent(QMouseEvent*) + 0x9c (QtGui.so.4) 0x1aead9: QWidget::event(QEvent*) + 0x5d9 (QtGui.so.4) 0x5b70f3: QFrame::event(QEvent*) + 0x33 (QtGui.so.4) 0x656392: QAbstractScrollArea::viewportEvent(QEvent*) + 0x32 (QtGui.so.4) 0x710265: QAbstractItemView::viewportEvent(QEvent*) + 0x525 (QtGui.so.4) 0x753d1a: QTreeView::viewportEvent(QEvent*) + 0x14a (QtGui.so.4) 0x1798c1: QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) + 0x91 (QtCore.so.4) 0x1489a3: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0x93 (QtGui.so.4) 0x151104: QApplication::notify(QObject*, QEvent*) + 0x18f4 (QtGui.so.4) 0x17947b: QCoreApplication::notifyInternal(QObject*, QEvent*) + 0x7b (QtCore.so.4) 0x14b9a2: QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 0xf2 (QtGui.so.4) 0x1dafe6: QApplication::x11ProcessEvent(_XEvent*) + 0x1966 (QtGui.so.4) 0x17850d: QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0x4d (QtCore.so.4) 0x17879a: QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 0xaa (QtCore.so.4) 0x17a811: QCoreApplication::exec() + 0xb1 (QtCore.so.4) 0x148317: QApplication::exec() + 0x27 (QtGui.so.4) 0x633f: __gxx_personality_v0 + 0x373 (quartus) 0x23208: msg_main_thread(void*) + 0x18 (ccl_msg) 0x5e5e: thr_final_wrapper + 0xe (ccl_thr) 0x23f1b: msg_thread_wrapper(void* (*)(void*), void*) + 0x6c (ccl_msg) 0x1591d: mem_thread_wrapper(void* (*)(void*), void*) + 0xdd (quartus) 0xffd8: err_thread_wrapper(void* (*)(void*), void*) + 0x2a (ccl_err) 0x62ba: thr_thread_wrapper + 0x2f (ccl_thr) 0x367c7: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xb7 (ccl_msg) 0x6411: __gxx_personality_v0 + 0x445 (quartus) 0x194d3: __libc_start_main + 0xf3 (c.so.6) 0x61f1: __gxx_personality_v0 + 0x225 (quartus) End-trace Quartus II 32-bit Version 12.1 Build 177 11/07/2012 SJ Full Version PID TTY TIME CMD 2157 pts/1 00:00:15 quartus 2194 pts/1 00:00:02 quartus_sh 2197 pts/1 00:00:00 system-console 2198 pts/1 00:00:00 sh 2199 pts/1 00:00:07 java 2355 pts/1 00:00:00 ps 3650 pts/1 00:00:00 bash this is service request # 10926503 at Altera
