ANi
6 years agoExport design partitons Problem
quarus prime standard edition 中 Export design partitons 生成的post-sythesis 或者 post-fit 文件都是xxx.qxp 而quartus prime pro edition 中 Export design partitons 生成的sythesis 或者final 文件是xxx.qdb。 qu...
KennyT_altera
6 years agoNope, each of the qdb or qxp are using a different format. You can't reuse it on different type of Quartus (pro/std)
