11 years agoExport and reuse change from Quartus Change Manager?
as an ardous workaround for my problem posted here http://www.alteraforum.com/forum/showthread.php?t=48731, I can change all LUTs by hand in the Quartus Resource Property Editor: 1) The original routing as done by the compiler: http://www.alteraforum.com/forum/attachment.php?attachmentid=10680&stc=1 2) I manually change the routing and the SUM Equation: http://www.alteraforum.com/forum/attachment.php?attachmentid=10681&stc=1 3) I see the changes in the "Change Manager". http://www.alteraforum.com/forum/attachment.php?attachmentid=10682&stc=1 But I don't really want to do this for all of my ROs. So, I thought I could export these changes in a TCL file and then write a skript to create equivalent TCL-commands for all my other ROs. But I was not even able to reuse the obove changes after export. I am probably missing something... The export gave me the following:# Quartus II 32-bit Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Full Version# File: C:/Users/user/Desktop/test/output_files/changes.tcl# Generated on: Fri Jun 05 18:50:49 2015
# Note: This file contains a Tcl script generated from the Change Manager.# You can use this script to reapply the changes to the design after# a compilation; use "quartus_cdb -t changes.tcl".
package require ::quartus::chip_planner
package require ::quartus::project
load_chip_planner_utility_commands
project_open test -revision test
read_netlist
set had_failure 0
# ############ Index: 1# # ###########
set node_properties
set result
if { $result == 0 } {
set had_failure 1
puts "Use the following information to evaluate how to apply this change."
dump_node $node_properties
puts "Original command:"
puts "\tIndex\tNode Name\tChange Type\tOld Value\tTarget Value\tCurrent Value\tDisk Value\tComment"
puts "\t1\t|test|lut_function:inst|lut_o~0:DATAA:0\tModify Source\tDisconnected\t|test|button1~input\t|test|button1~input\tDisconnected\tTRUE\tFALSE"
puts "\t1.1\t|test|lut_function:inst|lut_o~0:DATAA:0\tInput Port Modification\tNone\tExists\tExists\tNone\tTRUE\tFALSE"
puts "\t1.2\t|test|lut_function:inst|lut_o~0:DATAA:0\tSource\tDisconnected\t|test|button1~input\t|test|button1~input\tDisconnected\tTRUE\tFALSE"
remove_all_record_instances
# ############ Index: 2# # ###########
set node_properties
set result
set had_failure 1
puts "\t2\t|test|lut_function:inst|lut_o~0:DATAC:0\tModify Source\t|test|button1~input\tDisconnected\tData Not Available\t|test|button1~input\tTRUE\tFALSE"
puts "\t2.1\t|test|lut_function:inst|lut_o~0:DATAC:0\tSource\t|test|button1~input\tDisconnected\tData Not Available\t|test|button1~input\tTRUE\tFALSE"
puts "\t2.2\t|test|lut_function:inst|lut_o~0:DATAC:0\tInput Port Modification\tExists\tNone\tNone\tExists\tTRUE\tFALSE"
puts "\t2.2.1\t|test|lut_function:inst|lut_o~0\tSum LUT Mask\t0FFF\t0FFF\t55FF\t0FFF\tTRUE\tFALSE"
puts "\t2.2.2\t|test|lut_function:inst|lut_o~0:DATAC:0\tInput Port Modification\tExists\tNone\tNone\tExists\tTRUE\tFALSE"
# ############ Index: 3# # ###########
set node_properties
set result
set had_failure 1
puts "\t3\t|test|lut_function:inst|lut_o~0\tSum LUT Mask\t0FFF\t55FF\t55FF\t0FFF\tTRUE\tFALSE"
puts ""
set drc_result
if { $drc_result == 1 } {
puts "check_netlist_and_save: SUCCESS"
} else {
puts "check_netlist_and_save: FAIL"
if { $had_failure == 1 } {
puts "Not all set operations were successful"
project_close
It works when running quartus_cdb -t changes.tcl in the ordinary windows console. But to see the effects, I have to close and reopen my Quartus project. Isn't there a way to import the changes from within Quartus? When I try source changes.tcl in the Quartus TCL console, I get: Error:ERROR: Unable to find Chip Planner netlist. Read the netlist by using the "read_netlist" command. Error: while executing Error:"get_port_by_type -node 8 -type oport -port_type OUT -literal_index 0 -as_gen_id" Error: ("eval" body line 1) Error: invoked from within Error:"eval $fixed_cmd " Error: (procedure "execute_tcl_command" line 3) Error: invoked from within Error:"execute_tcl_command $cmd " Error: (procedure "make_ape_connection_wrapper" line 34) Error: invoked from within Error:"make_ape_connection_wrapper $node_properties |test|lut_function:inst|lut_o~0 DATAA 0 |test|button1~input OUT 0 -1 " Error: invoked from within Error:"set result [ make_ape_connection_wrapper $node_properties |test|lut_function:inst|lut_o~0 DATAA 0 |test|button1~input OUT 0 -1 ]" Error: (file "changes.tcl" line 46) Error: invoked from within Error:"_source changes.tcl" Error: ("uplevel" body line 1) Error: invoked from within Error:"uplevel 1 $cmd " Error: (procedure "source" line 5) Error: invoked from within Error:"source changes.tcl" Thanks and best regards!No RepliesBe the first to reply
