17 years agoExpected ALTPLL behaviour
Hello all,
I would welcome some clarification on the expected behaviour of an ALTPLL when operating with a single compensated output clock in NORMAL mode. From the Stratix II GX Device Handbook Vol 2 page 7-23 I understand that in NORMAL mode the clock at the input pin of the device and clock at the target data register should be aligned - in other words, any delay on the input clock path (all the way from the input clock pin) is removed. However, on my current design (8ns period, EP2SGX90EF1152C5N device), I have the following delays in the clock path. Input pin (AN19) to the PLL input : 4.130ns. PLL output to a CLKCTRL block input : 1.303ns. CLKCTRL block output to the target I/O register : 1.524ns. So a grand total of 6.957ns. A list_path report (setup) for the register of interest is saying that the offset between the PLL input and output is -3.082ns. I'm totally confused by this figure, and uncertain as to what is actually being compensated for here - any help/clarification would be appreciated. Declan.
