14 years agothis is just part the coding,
library ieee; use ieee.std_logic_1164.all; entity lut_0 is port( a,b,c,d : in std_logic; i0 : in std_logic:='0'; i1 : in std_logic:='1'; i2 : in std_logic:='0'; i3 : in std_logic:='1'; i4 : in std_logic:='1'; i5 : in std_logic:='0'; i6 : in std_logic:='0'; i7 : in std_logic:='1'; i8 : in std_logic:='1'; i9 : in std_logic:='0'; i10 : in std_logic:='0'; i11 : in std_logic:='1'; i12 : in std_logic:='1'; i13 : in std_logic:='0'; i14 : in std_logic:='1'; i15 : in std_logic:='0'; enable : in std_logic; FA : inout std_logic ); end lut_0; architecture ar of lut_0 is component latch port( d : in std_logic; enable : in std_logic; q : out std_logic ); end component; component sel_fa_0 port( a,b,c,d : in std_logic; l0,l1,l2 : in std_logic; l3,l4,l5 : in std_logic; l6,l7,l8 : in std_logic; l9,l10,l11 : in std_logic; l12,l13 : in std_logic; l14,l15 : in std_logic; Output : out std_logic ); end component; signal w0,w1,w2,w3,w4,w5,w6,w7,w8,w9,w10,w11,w12,w13,w14,w15 : std_logic; begin u0: latch port map(i0,enable,w0); u1: latch port map(i1,enable,w1); u2: latch port map(i2,enable,w2); u3: latch port map(i3,enable,w3); u4: latch port map(i4,enable,w4); u5: latch port map(i5,enable,w5); u6: latch port map(i6,enable,w6); u7: latch port map(i7,enable,w7); u8: latch port map(i8,enable,w8); u9: latch port map(i9,enable,w9); u10: latch port map(i10,enable,w10); u11: latch port map(i11,enable,w11); u12: latch port map(i12,enable,w12); u13: latch port map(i13,enable,w13); u14: latch port map(i14,enable,w14); u15: latch port map(i15,enable,w15);
