lucie-sharpe
6 months agoError(23098) when using IPM_IOPLL on Agliex 7
I am trying to use the IPM_IOPLL in my project on the Intel Agilex 7 FPGA I-Series Transceiver Development Kit (6x F-Tile) but whenever i use it i get the following error: Error(23098): One or more...
ShengN_altera
6 months agoWhat settings you're using for the IOPLL ip from platform designer?
lucie-sharpe
6 months agoHere are my settings from Platform Designer. I have also tried the N,M and C values listed under Advanced parameters with no change.
- ShengN_altera6 months ago
what are your outclock_0 and outclock_1 frequency?
- lucie-sharpe6 months ago
outclk_0 is 125MHz and outclk_1 is 62.5MHz which are used for the Intel TSE IP. outclk_2 is 31.25MHz which is used for IPBus communication.
Seems like a bug for me. Let me further confirm and get back to you. I try other frequency like outclk1 100mhz, outclk2 100mhz and outclk3 100mhz, there's no problem. Seems like only certain frequency combination will cause issue.
