billmax
2 years agoError(19496) & Error(19296)
I have an Agilex 7 design I'm building under Quartus Prime Pro 23.2.0 Build 94. It's not a new design but is in ongoing development, and has been built successfully quite a few times over the last s...
TingJiangT_Intel
Contributor
2 years agoThe best way to check the files is to reinstall Quartus and make sure that access permissions to the installation path are available.
If this issue still exist, you can provide a demo with the same problem for the further investigation as the your original design can't be showed.
