alexislms
Contributor
4 years agoError(18948): Error message received from device: Internal error. (Subcode 0x001A, Info 0x00000000,
Same question:
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Error-18948-Error-message-received-from-device-Detected/td-p/1272326?profile.language=de
While programming the design, ...
YuanLi_S_Intel
4 years agoSorry for causing misunderstanding. Please ignore what i have said, the refclk should be the issue based on the error message.
Meanwhile for the assignment, it meant for preserving all unused PMA lanes in all unused tiles in a package. As per user guide, it may lead to configuration if the assignment is OFF. If it is passing in your programming, I don’t see any issue.
